MathScript RT Module installing issue
Greetings!
I am a student and using LABView 2015 (64-bit). I am trying to install 2015 MathScript RT Module but it is showing error "No software will be installed or removed". Please guide me what is the issue and what could be the possible solution.
(3,613 Views)
Have a look at the Readme:
https://www.ni.com/pdf/manuals/375325a.html
Or look at this thread:
https://forums.ni.com/t5/LabVIEW/LabVIEW-MathScript-RT-Module-x64/td-p/3332086
There's no Mathscript RT Module compatible with LabVIEW 2015 & a 64bit OS.
Regards, Jens
Kudos are welcome...
(3,608 Views)
Accepted by topic author imran6899
The obvious solution is to change to LabVIEW 32bit, which is the right choice in 99% of cases. Do you have a reason for 64bits (e.g. gigantic data structures)?
(3,604 Views)
It is working flawlessly on 32bit. Thank you for your timely response.
(3,571 Views)
