MathScript within For loop
It depends how you want the data arranged in the final 2D array. Can you describe it?
Message 11 of 13
(891 Views)
I've been experimenting with the Reshape Array vi and have come up with a solution that I believe works.  I've attached a vi with my efforts, it may not be very pretty or the best way to achieve what I want but its getting close.
Message 12 of 13
(888 Views)
Why do you index the same array twice? That is an unecessary allocation of a large data structure. Simply branch the scalar wires right before the mathscript node.
Also, index array is resizeable, so you only need one instance at the end.
I am sure there are much better ways to do all this.
Message 13 of 13
(881 Views)
