Mathscript print command????
In LabVIEW 8.5, you are unable to print the plot window created by MathScript Window or Node programatically. LabVIEW 8.5 does not provide print command. To print the plot window, you can use the menu item File->Print Window... To export the plot window into image file, you can use either the menu item File->Save to BMP/EPS File... or the short-cut menu item Export Simplified Image...
Why do you want to print the plot programatically? Would you please let me know your use case?
Look forward to your reply.
Message 11 of 15
(2,444 Views)
Yes, I was aware of the point and click method.
Use case 1.  Produce a gazillion plots of data and send them to a printer while I surf the internet for evidence of life on Mars.
Use case 2.  Print a bazillion plots to a (jpeg|tiff|bmp|ps|eps|...) files for later insertion into MSWord|TEX|etc journal articles, papers etc.
LV 8.6 on Windoze XP
Message 12 of 15
(2,436 Views)
Appreciate!!! Your use cases make sense. We will consider your requirement.
In LabVIEW 8.5, the workaround is to use MathScript Node for analysis and XY Graph control for displaying. You can use the Export Image method of XY Graph to save the plot into image file programatically. The attached snapshot illustrates a simple example.
Message 13 of 15
(2,432 Views)
Hi i have the same problem. I can't save the picture of follow m-code.
%beginn
subplot(2,1,1)
plot(x, y)
subplot(2,1,2)
plot(x2, y2)
%end
How i can save this plot automatic, i knew that i can save thit in "file" -> "export" or "file"-> "save as EPS" or so, but i have to much plots and i want save this automatik.
any ideas?
thank's
Message 14 of 15
(2,244 Views)
I have the same request. For creating simple plots to import in to text reports, the LabVIEW front panel images are too graphical to look good in simple text reports. Being able to export mathscript plot programitically would be great.
Doug Ferguson
Message 15 of 15
(2,180 Views)
