Matlab DataPlugin Crashes
Hi everybody,
I have encountered a problem when I use this DataPlugin (or I think so...)
Sometimes it appears this exception...
Somebody has the same problem?
It appears when I am converting mat file to TDMS file, with the Convert to TMD or TDMS.vi.
But before, It appears when I opened mat file and get properties and something like that.... due to this, I changed to convert to TDMS file before analyzing it., but the problem still continues
Somebody can help me?
(2,118 Views)
What's happening when you click [OK]?
(2,029 Views)
Thanks for your answer.
Nothing happens, because LabVIEW is already closed.
I think NI has a problem with Matlab Data Plugin... I have analyzed it with "Desktop Execution Trace Toolkit" and there are a lot of "Memory Leaks"....
(2,019 Views)
Ok so basically LV is crashing.
There is the following article regarding the error 0xC0000005, I would recommend you to have a look at it, if you haven't done yet:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9TXSA0&l=en-US
(2,016 Views)
Thank you!!
I saw it but it is not the same problem.
I am talking to NI in order to solver it.
(1,991 Views)
