Max errors on deployment
Not sure if this shouldn't be a Test Stand problem since it happened during deployment but Max supports my VIs.
When I start Max I get this message:Max encountered an unexpected error since it was last run. For more info, visit ni.com/info and enter the Info Code MaxKnownException.
It also gave me this two attahced files.
thanks,
jvh
PS - Had to add .txt to .dmp to get it posted.
(2,874 Views)
jvh75021,
What operating system are you using?  What other NI software do you have on your computer and what versions?
You could try running the MAX Database Corruption Removal Tool (requires LV2009+)
https://forums.ni.com/t5/Example-Code/MAX-Database-Corruption-Removal-Tool/ta-p/3521466
Or completing the steps in the article below (the Corruption Removal Tool does these steps for you)
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8awSAC&l=en-US
Sam K
www.ni.com/support
(2,836 Views)
