Target-scoped FIFO
I'm using one Target-scoped FIFO for pre-triggering and I would like to know (if I use block memory) what is the maximum 'Number of Elements'.
The memory takes place only in the FPGA or is it uses the cRIO memory too? (I use cRIO-9014)
Thanks!
Mark
(3,147 Views)
Accepted by topic author markoka
In case you didn't find an answer yourself in the meantime:
<http://zone.ni.com/devzone/cda/tut/p/id/7056#toc4>
You need to know, which Chassis you're using, and which FPGA chip it contains. Then look the built in block memory available in the table.
By the way, the table in the english version seems corrupted. I used the german one.
Simo
(3,089 Views)
