Max value across multiple pages in 3D array for all individual rows and columns
Hi all,
I have multiple 2D array data sets stacked in a 3D array. I want to know the maximum vale for each XY position accross all data sets.
Is there a easy way to do this?
To better explain myself, a simple example:
Data set 1 (page 1 in 3D array):
1   2   3
4   5   6
7   8   9
Data set 2 (page 2 in 3D array)
1   4   7
2   5   8
3   6   9
Data set 3 (page 3 in 3D array):
1   3   6
2   5   8
4   7   9
Wanted result (max values for each xy position):
1   4   7
4   5   8
7   8   9
FYI, the actual data exists out of much more rows, columns and pages.
Thanks in advance!
(3,676 Views)
Accepted by Brandts
Hey,
I've got a quick example using your values. It should work for larger sets of data.
I hope this helps.
Nic
Nico
Systems Engineer
Certified TestStand Architect Certified LabVIEW Architect
(3,653 Views)
Thanks, this works great.
I also learned something new because I thought "Index Array" could only be used to get a single value.
(3,643 Views)
Great!
The Index Array will give you everything that matches the indexes you input. It can be used to take out a single element, a row, a column, a page... as long as you specify the indexes correctly.
Glad this helped!
Nic
Nico
Systems Engineer
(3,640 Views)
Accepted by Brandts
Here is a simpler version of Nico011's solution (using autoindexing for the output).
(3,636 Views)
This one looks indeed a lot easier!
Thank you for your improvement.
(3,611 Views)
