Mean Fonction (?)
@crossrulz wrote:
Ok, one final benchmark in attempt to put this DLL call slow business to sleep.  Here is how I figured NI is doing the average: Sum(X/size(X)).
Exactly. NI is doing the right (but more expensive!) thing to avoid overflow for large numbers. Doing N divisions instead of 1 simply costs more. 😉
If we compare apples with apples, the DLL call is significantly faster.
(Personally, I would turn the constants into controls, place the indicators after the sequence structure and disable debugging, but it does not really make a difference here.)
Message 11 of 22
(1,469 Views)
Out of curiosity I wanted to implement an "almost" correct version in LV by utilising the size of the array and a scale by power of 2.  I was still several times slower than the NI VI.
I then realised there was NO primitive to simply scale a Floating point number (FXP yes, SGL, DBL etc. no).  The "Scale by power of 2" does some extra work (Again probably due to the IEEE Floating point standard).
Does LV have no way of manipulating the mantissa directly in this way?
Shane.
Message 12 of 22
(1,455 Views)
Also if you show more decimal digits, you'll see that the two answers are not identical.
Shane
Message 13 of 22
(1,444 Views)
Actually things seem to be even more complicated. The Sum(X/size(X)) would fail when averaging values very near to the double precision lower range.
But although the simple Sum(X/size(X)) returns 0, the Mean vi still returns a nonzero value.
Paolo
Message 14 of 22
(1,434 Views)
Nice catch.  My benchmarking confirmed this.  So NI is somehow taking care of all the weird situations for us.  Does anybody have any ideas for an algorithm that can take care of both the small numbers and the really high numbers without over/underflowing to INF/0?  Not like it really matters.  I'm sure that code has been tweaked and optimized as much as can be.
So the moral of the story is to just use the built-in Mean.vi unless you will for sure not be dealing with large numbers AND you need the mean to be done very fast for whatever reason.
GCentral
Message 15 of 22
(1,409 Views)
Message 16 of 22
(1,383 Views)
here is the real time to call a dll
approximately 43µs (Q6600 XPsp3 2.6Gh 4Go)
Message 17 of 22
(1,350 Views)
As always, please attach your entire benchmarking code, not just the dll. We cannot see how the CLFN is configured.
Message 18 of 22
(1,337 Views)
i don't understand why you cannot see how the CLFN is configured (?)
It's a snippet ... I just do it now .. no problem.
the file is attached.
Message 19 of 22
(1,327 Views)
This leads to the question of how parallellized the DLL is.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 20 of 22
(1,313 Views)
