Measure DVM functions returns 0
My voltage measurement VI returns 0 every 200-500 calls. This function is used to measure voltage on a shunt. When I put a breakpoint when that happens I can see on the DVM front panel (Agilent 34411A) a different voltage value. Also as it measures voltage on a shunt there's always some noise if if there's no current flow, meaning some millivolts, never 0.
Any ideas will be appreciated.
CT
(4,206 Views)
Are you getting an error at all when this happens?  Is the driver truncating the value to 0?
(4,199 Views)
Not getting an error. I had all VI's visible when that happened, no errors ( I had a breakpoint set in TestStand). Then I clicked "Run" again and received 0.00745236.
CT
(4,174 Views)
Are you using the serial port?
I have seen simlar zero readings when using the serial port. I ended up implementing a check on how many characters are read.
(Or say: the read function in that driver maybe doesn't catch a false reading (maybe due to a EMC spice on the serial line)  and outputs the default (zero) value. )
Greetings from Germany
Henrik
LV since v3.1
(4,157 Views)
No, the DVM is connected through USB to a D-Link hub and then to PC.
I am using XP
CT
(4,147 Views)
However, if you dig into the driver you will find the core reason:
the input string is not checked, so if you read (for what ever reasons) something that the spreadsheet string to array coudn't convert correctly, it will turn out as a zero value.
**bleep** happens, so you have to implement a string check (use the error out from scan from string)
Henrik
LV since v3.1
(4,136 Views)
