Measure flexiforce sensor output from labview
How to connect flexiforce sensor without ELF system with PCI-DAS6013 and how to use LAbview to measure the forces?
(3,967 Views)
I wasn't able to find anything about flexiforce nor PCI-DAS6013 on NI web site. Do you have PCI-6013 or is it a DASyLab hardware?
NI PCI-6013
NI 6013 Specifications
Zvezdana S.
(3,967 Views)
THe flexiforce sensor A201 is from tekscan aand as for the PCI-DAS6013 is from measurementcomputing.
(3,967 Views)
