Measurement&Automation locks after trying to expand 'devices and interfaces' .
Measurement and Automation Explorer locks up when 'devices and interfaces' is selected. It started up properly only once. There is a DAQ board attached and three GPIB instruments. Two of the GPIB instruments have not been turned on yet.
(2,580 Views)
You may want to wait for a while (as in minutes), it usually comes back.
-Khalid
(2,573 Views)
You may also want to make sure you're using a current version of MAX - version 4.1 included speed improvements over the earlier versions that you might find beneficial.  MAX comes with most of our drivers (including our DAQ driver), and these drivers can be downloaded from our Current Driver Versions page.  What version of MAX and the DAQ and 488.2 drivers are you using?
Cheers,
Matt Pollock
(2,559 Views)
