Measuring FWHM of multiple pulses from an oscilloscope
I am measuring the FWHM of a laser which has two distinct pulses. I need to measure the FWHM of each pulse individually, but the scope only records the first pulse's width. Any tips?
Thanks!
(1,172 Views)
Hi apyonchak,
First hint: when using specific abbrevations you should explain them or provide a link like this!
2nd hint: when your scope doesn't provide the data in a way you need them then you need to change the settings of the scope!
Please provide more information on your specific problem to get more detailed suggestions!
Which scope do you use?
How do you get data from your scope?
Mind to attach your VI(s)/LabVIEW project? (Do you use LabVIEW at all?)
(1,170 Views)
