Measuring Temperature
Hello there !
I am a real LabView beginner. I have several temperature probes
(Pico Tech) and a AD converter (serial). I can read the temperature inputs
with the software provided with the probes but am unable to read
them under LV. What can I do ? Are there any ready Vls ?
Cheers,
Fred.
Message 1 of 22
(7,615 Views)
You can download free drivers from www.picotech.co.uk. This should get you started.
David
Message 2 of 22
(7,610 Views)
Thank you very much.
I downloaded everything and it seems to be exactly what I needed.
Still, the vi is not executable, it displays the following error message
"The function name specified for this node cannot be found in the library.
Right-click the Call Library Function node and select Configure, then
choose the correct function name."
The library exists, I looked it up. It's the pt10432.dll library inside the examples
folder. It should call the "pt104_labview" function, which apparently it's not
able to do.
I have LV 8.0, maybe it is a compatibility problem ?
Thanks in advance for your help,
FdB
Message 3 of 22
(7,599 Views)
Not sure. I have a TC-08 from them and the drivers worked just fine.
Can you attach the drivers file you downloaded? I could have a look at here. I don't have the device so I could only go so far but a few educated guesses might be in order.
David
Message 4 of 22
(7,601 Views)
Here are the attached files. (the bugging library and the vi requesting it)
Thanks for your help.
Message 5 of 22
(7,589 Views)
sorry, he doesn't want the .dll file to be attached
here it is unter .xls
I don't know if it helps.
Thanks.
Message 6 of 22
(7,587 Views)
I would like to install what you downloaded from the Pico website. Did you download a .exe installer or .zip file? If so can you attach that.
David
Message 7 of 22
(7,580 Views)
Double click the Call Library Function Node to get this
Just make sure Library Name Or Path is where the .dll is stored on disk in the location you installed it. If its not click on the browse button to update to the correct path.
Hopefully everything will be OK once you have done that.
David
Message Edited by David Crawford on 06-27-2006 02:34 PM
Message 8 of 22
(7,579 Views)
I checked it, it was already ok.
It tells me the function cannot
He doesn t accept exe files
either, I cannot attach the install
file.
Message 9 of 22
(7,572 Views)
OK. I will get it from the website direct. I might be able to work it out from the driver file name but what model are you using?
It does seem strange that CLFN asks for a function not available in the DLL. Ultimately it might be a question for Pico Tech Support.
Give me 10 mins to do  the download and have a look at it. I will be right back....
David
Message 10 of 22
(7,570 Views)
