Measuring current on a Voltage Rail > 10V
I am attemting to measure the current and voltage on a 15V power rail.  (Here is a copy of my circuit attatched) I am using a USB-6225 DAQ and Lab View,
 I have my device under test connected to a power supply. I have connected two differential channels to the DAQ, one for the current and one for the voltage.
I understand that the DAQ can not handle more than 10V so I use a voltage divider to half the voltage. When I run the measurements, the current reported is incorrect. It shows 10A when it should be about 500mA.
When I reduce the voltage on the power supply to 10V, it all works fine, so I am guessing its got something to do with the 10V limit.
Please can you advise how I can connect this up correctly?
(3,308 Views)
Why are you posting a hardware issue to a software forum?
Bill
CLD
(Mid-Level minion.)
(3,294 Views)
R(Sense) should be within 10 volts of the DAQ chassis.  Thats all the common mode rejection you are likely to have on a DAQ device.  (But check your device specification sheet ---- don't trust me RTFM!)
if you do not have a common "Ground" between the DAQ device and the supply you are monitoring  you will need an opto-coupler (But any first year EE student could tell you that)
As an Asside.:  Who the hell ever started the convention of stuffing R (sense) on the + side of a circuit anyhow?  Use a regulated supply with "Remote sensing"  if you really care about the DUT power consumption.
(3,282 Views)
Accepted by rodwatt
Do it this way.
=== Engineer Ambiguously ===
(3,268 Views)
Great, that worked!
Thank you very much for your constructive feedback and suggestion, much apprecited!
(3,249 Views)
High side current sensing does prevent ground disturbances for sensitive or high speed PWM/Inverter circuits.
I think it can be used for additional diagnostic info that low side can't provide, can't recall.
EDIT: Forgot- with high side you can use multiple sensors to monitor current of multiple loads on a common ground buss.
Never had a need to use it though.
-AK2DM
(3,226 Views)
