Measuring current using USB 6009 with a Rheostat as shunt resistor
@CoolKiat wrote:
So back to the first question, can I use the rheostat to measure the current. If can, how do I specify the resistor value in the current set up measurement.
You need a fixed, known resistance in order to properly measure current.  I would recommend getting something line a 1 Ohm resistor (depending on how high your current will be).
Message 11 of 16
(2,752 Views)
This is not making any sense. You started out asking about current from a battery, now you mention a solar cell.
Have you got a diagram of what you are trying to achieve?
How would you connect things using a voltmeter and ammeter?
Message 12 of 16
(2,746 Views)
Accepted by topic author kiatkiat
@CoolKiat wrote:
As for why I need to measure the current using a rheostat is because I want to measure the voltage and current of a Solar cell using the 'variable load method'. Therefore a rheostat is necessary.
No, you cannot use a rheostat to measure current. You need an ammeter to measure current OR measure the voltage drop across a known fixed resistor. And your rheostat is not used as the shunt.
This diagram was taken from http://physastro.pomona.edu/wp-content/uploads/2012/09/Berkley-Thesis-addendum.pdf:
And this modified diagram shows you what we have all been trying to tell you:
Message 13 of 16
(2,717 Views)
Hi Sebster,
I've now fully understand everything. Really appreciate and thank you so much for helping me.
Message 14 of 16
(2,646 Views)
Don't you think you should give credit (kudos) to everyone who told you the same thing over and over again?
Bill
CLD
(Mid-Level minion.)
Message 15 of 16
(2,612 Views)
CoolKiat
What university (or other institution) are you studying at?
Message 16 of 16
(2,587 Views)
