Measuring themocouples with SCXI-1000 SCXI-1102 SCXI-1600 and 1303 "
    I need create a sistem, using Labview, to measure and register the readings of 13 thermocouple sensors using SCXI-1000, SCXI-1102, SCXI-1600 and 1303 Isotermal Block. Is there any application avaiable in NI Data base or anyone would have an similar application? Tips will be also welcome.
(2,648 Views)
Go to Examples shipped with LabVIEW
Find Examples>>hardware input output>>DAQmx>>Analog measurement >>Temperature folder will have thermocouple based measurement example vi's
Or, Find Examples>> In search tab, Type 'Thermocouple' and your search will yield all relevant examples that will work with SCXI 1102 for making Thermocouple measurement.
It should be the best place for you to start
Also read this tutorial for thermocouple measurements using SCXI 1102
Note: I suggest that you use VI's that are built using DAQmx functions
Any doubt, do ask
Dev
Message Edited by devchander on 11-09-2006 12:28 AM
(2,641 Views)
