Measuring voltage drop across resistor using NI-5164 Scope with two single ended probes
Hi all
I develop LabVIEW code to measure voltage drop across resistor using NI-5164 Scope with two single ended probes but I got time out error. Does anyone have an idea to solve this issue.I greatly appreciate your help
Sattam
(2,709 Views)
Hi Sattam,
Unfortunately I have just re-imaged my PC so I don't have that driver installed... But have you seen this guide and gone through its suggestions?
Error -1074126845: Maximum Time Exceeded Before the Operation completed.
(2,701 Views)
Accepted by topic author Sattam
I don't see anything sending the trigger on RTSI2.  Perhaps you need your trigger to be Immediate instead of a Digital Trigger.
(2,687 Views)
(2,670 Views)
