Memory considerations while using the Queue and Functional Global techniques
You can chunk data in a queue by having a queue with multiple elements, but you can only process the chunks in queue order.  I don't know if that's a good fit for your application.  It sounds like the functional global might be a better choice for you.  However, the best thing you can do to improve efficiency and decrease memory use will be to replace all your strings with numeric values wherever possible.  If your non-numeric data can only have a limited range of values, you can convert them easily to numerics by using an enumeration.  String formatting functions such as Scan From String and Format Into String can handle enumerations and will automatically them convert to and from strings.  Make sure that you're not storing your data simultaneously in memory as both strings and numbers.  Can you post your code, maybe just the problem spots?
Message 21 of 64
(3,296 Views)
I agree about posting your code that is troublesome.
Since I will not be available today (yet another day behind the barbed wire) Let me say a couple of things.
Avoid strings when possible since they gooble up memory. Convert to numerics as soon as possible.
Since you are touching the same dat repeatedly and your data sets sound large, you maybe headed toward a specail AE to do your work. Short war story. A customer wanted to do cyclic voltametry at high rates. Inital development used queues to pass data from DAQ to display and logging. this was fine. When adding post processing and analysis they ran out of memory after long runs at high rates (customer did not anticipate LV would be able to run that fast but loved it when he found out). Analysis showed that his data sets required a good portion of the availabe physical memory. So we turned things inside out and replaced queues with an action engine that had an action for each procesing step (including saving to file). Using that approach we kept all of our data in one buffer and only pulled out the peices we need. Last I heard he was patatenting the system.
So I think you will end up with a AE in the end.
Have fun and "may all of your wires be straight and your buffer re-used" Smiley Wink
Ben
Message 22 of 64
(3,277 Views)
For the queue approach, you actually can chunk your data very efficiently by using an array of queues. Instead of an 2D-array of 10x10000 data elements you could use 10 single-element queues with an 1D array of 10000 elements. So each time you access one of those 10 sets, all necessary buffer allocations/data copies are only made for the 10,000 elements and not all 100,000 elements.
This technique is also not in contrast with the AE approach, but might nicly fit in.
Felix
Message 23 of 64
(3,269 Views)
Thanks nathand, I didn't realize that I could have multiple items in a queue, I have never actually used them I am just begining to learn about them now. That is useful and I will keep that in mind as I determine whether to go with a FG or a queue.
I would post my code but I feel it would be very difficult for anyone else to be able to go through it, the code is spread across many VI's and it is not very easy to follow.
Thanks for input Ben, the data is being accessed a few times throughout the code. I have already started developing the FG for this data and think I am going to go this route for now anyway and see where it gets me. I would like to take advantage of this oppurtunity to learn how to create and use FG's even if I don't end up sticking with them in the end.
Thanks for that idea Felix, I hadn't thought of that either. I will consider implementing this mehtod also.
Thanks for everybody who contributed and helped me out with some ideas. I think you guys gave me enough knowledge to be able to get started anwyay with these modifications to the code to try and improve memory performance.
Wow, this has really been a great experience.... I don't know how I have been writing LabVIEW code without this message board over the past year!! There is so much help and very knowledgeable people here. When I first considered about posting some questions here I didn't anticipate this much respone at all, and especially the speed of the responses, I had answers within an hour (Thanks to Ben)!!!  To me, that is unbelievable. I will definitely be back soon.Thanks again guys :smileyhappy:
Message 24 of 64
(3,249 Views)
I told you I'd be back.... I am wondering what the most efficient way to build the data in a FG is. If I know the final size of the array should I intitialize it to be that size at the begininng and then use the replace subset fucntion to chunk in my data? Or should I grow the size of the array within the FG as I chunk in my data. I am currently using the reshape array fucntion to intitialize the array because it seems not to create a buffer when compared to the intitialize array function. Here is my initialization case:
Initialize FG Data
 Thanks for any help.  Smiley Happy
Message 25 of 64
(3,237 Views)
The image you embedded in the body of the message doesn't show up.  If you are going to embed an image in your message, you can't do it while in preview mode.  That just points the image to a temporary location on the NI webserver.  You must attach the image file then submit the message.  Then the message and thus the image will have a permanent ID number and location on the server.  Then you use that path (found by right-clicking and selecting properties on the attachment in the now posted message) by going back in, editing the message and inserting the image with the link to the permanent location.
Message 26 of 64
(3,240 Views)
It will be more efficient to allocate the array once at its full size.  I would recommend that you use reshape array on the first chunk of data, then use replace array subset for the following chunks.  Initialize array may allocate a buffer unexpectedly when the array sizes are constants, is this what you're seeing?  See here for more details.
Message 27 of 64
(3,222 Views)
I want to be able to use the Replace Subset Array function but only have a 1D array of data. This 1D array of data does not have the same number of rows or columns as the 2D database array that I want to put it into. If I wire a 1D array to the New Array input of the Replace Array function I can only specify either the row or column, not both. But if I wire a 2D array to the New Array input of the Replace Array function I can wire both the row and column inputs of the Replace Array function, this allows me to place this 2D array anywhere in the database array. In this case it seems like it makes sense to use the Build Array fucntion but with only 1 input (the 1D array of data). Then I can put this 2D array (it is really on 1D of data though) in the database array anywhere I want. I know that the build array can be costly, but if I only have 1 input is there any additional buffers being created? Is this the most efficient way to do this? WHen I use the Show Buffer Allocation tool there doesnt seem to be any additional buffers being created. Thanks for any help
Message 28 of 64
(3,171 Views)
Thanks for you help nathand. Yes, that is exaclty what I was seeing.
Message 29 of 64
(3,174 Views)
If you're not seeing a buffer allocation then one isn't taking place.  Have you tried turning on the option (in preferences) to show constant folding?  If you're using a simple test VI you may find that the build array is folded into a single constant array, so no buffer allocation is needed - but your real life case is probably more complex.  I think you'll get the same results using either build array or reshape array, and both of them will cause a buffer allocation, according to this thread on LAVA (there's a question about reshape array towards the bottom of the first page, and I expect that build array is the same).
Message 30 of 64
(3,164 Views)
