Memory increasing in LV2009 but not in LV8.5
Hi.
I have developed application that is very simple. It opens 20 references of .NET object, call .NET method and close all 20 references. This is repeated every iteration. I am developing this application in Labview 8.5 but it will run in Labview 2009. So I am testing it in Labview 2009 evaluation. After one day application have crashed because of "Labview memory is full". I have noticed that memory is increasing constantly if application is running. Then I ran the same application in Labview 8.5 and memory usage has not changed since start (application is running for 3 days now). Is this because Labview 2009 is in evaluation mode or is problem somewhere else?
andrej
Message 1 of 12
(4,328 Views)
No help, but I also have a memory leak with a project that has .NET references. I am using 2009 f2. Depending on the device the software is talking too, I can turn off the .NET code, and when I do that, there's no memory leak.
I didn't check this back on 8.6 or 8.5, so I'm not sure if it's a new problem.
Richard
Message 2 of 12
(4,305 Views)
This is a real issue that NI is aware of and the have a CAR open for this issue. See the attached forum.
http://forums.ni.com/ni/board/message?board.id=170&thread.id=445095&view=by_date_ascending&page=1
Tim
GHSP
Message 3 of 12
(4,282 Views)
that thread said it is fixed with the f2 patch but Broken indicates he has f2.
So..
New bug
Bug not fixed
or Broken does not have f2.
Curious,
Ben
Message 4 of 12
(4,276 Views)
So..
New bug
Bug not fixed
Curious,
Ben
Message Edited by Broken Arrow on 12-16-2009 10:46 AM
Richard
Message 5 of 12
(4,260 Views)
Broken Arrow wrote:
So..
New bug
Bug not fixed
Curious,
Ben
So...
New bug
or
No fix
Ben
Message 6 of 12
(4,254 Views)
My memory leak is slow enough - and our need for the software to access to the .NET stuff is rare enough - that I haven't looked into the issue. My program will run for a few days with no problem. It may start off at 480MB and be at 650MB 48 hours later.
However, I must say that I'm not convinced it's the bug if the bug has been known to be fixed on f2. Reason is, the .NET vi's were supplied by a vendor, and upon my cursory glance at them, they appear to be a collection of turd balls. There could be references they are not closing, etc. I am closing what I use, but there could be other things going on inside them turds.
Richard
Message 7 of 12
(4,246 Views)
The bug fixed in f2 refers to .NET callbacks, not to simply opening and closing .NET references. I don't know of any CAR on that.
Jarrod S.
Message 8 of 12
(4,231 Views)
I have installed patch f2 but memory leak still remains.
Message 9 of 12
(4,186 Views)
Accepted by andrej
I wrote my previous post a little bit to fast. After additional testing I can confirm that there is no memory leak in my application after I installed patch f2.
Message 10 of 12
(4,157 Views)
