Menu Fonts in LabVIEW 8.6
I have problem with menu, Greek fonts in LabVIEW 8.6.
I installed the patch to support other languages and everything is fine at the development enviroment.
But at the exe (executable), the menu Greek fonts can not be displayed. At the exe front panel they are ok.
Any suggestions ?
(3,478 Views)
Accepted by Pnt
Open your labview.ini file with notepad (it is pure text). Copy the font settings into a labview.ini file in the same dir as the exe file. You will find more pointers in this thread -> http://forums.ni.com/ni/board/message?board.id=170&message.id=384369#M384369
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,462 Views)
I would check the Labview.ini file, for any keys that seem related to
(menu)fonts. The executable will also create an ini after it's first run if
it's not there (you can create one and distribute it in the installer). Copy
the related keys (in the same sections) from labview.ini to exe.ini.
Aren't menu fonts normally set in Windows?
Wiebe.
(3,460 Views)
Thank you both...
(3,441 Views)
