Menu ItemNames disregard first underscore character
Are there any characters that are not valid in a LabVIEW custom ItemName?
If you create an ItemName such as 'One_Two_Three' under a File Item, or even at the top-level it is displayed wrong.
Item Name:  One_Two_Three
Displayed as: OneTwo_Three
It seems the first 'underscore' is being cutoff.  When displayed it actually looks like the T (in Two) is underlined.
Is that expected behavior? Smiley Frustrated
I was working on some code to display a Recently Used File List in the File menu.  I was hoping to just read the filename (as ItemNames) but items with an initial underscore are causing this error.  I suppose there are some workarounds where I could just replace all "_" with some other character but that seems like more work than is necessary.
PH
(5,224 Views)
I should mention:  Using LabVIEW 2010 SP1.
(5,222 Views)
Accepted by Teds
Yes, it is expected behavior.
Using the underscore character ahead of a menu item defines that letter to be a shortcut for when you use the keyboard.  So it defines the T as the shortcut to pick that menu line.  Look at the regular LabVIEW menu and you'll see numerous menu items with underlined characters.
Is there a reason why you want to use an underscore character in your menu?  That is unusual and probably not recommended by some Microsoft UI guideline somewhere.
You could use a double underscore character for that first one.  Then it will appear as a single underscore character.  But then that will define the underscore as the shortcut key.  Or you could define a the letter O, n, or e as a shortcut, then that will free up that _T to become shown with an underscore and not defined as a shortcut of T.
(5,212 Views)
I wanted to put in the full path for recently used files in the File Menu.  It works fine except for paths with underscores in them.
Notice, though, what I said the 'underscore' is NOT at the beginning but it replaces the first underscore it sees, no matter where the position is located.
"One_Two_Three" is what I want to display in the menu.
What actually displayed is:
OneTwo_Three
So if any of my paths contain a "_" ANYWHERE in them it gets removed by LabVIEW as the ItemName.
PH
(5,196 Views)
I never said it was at the beginning of the menu item.  It is ahead of a character that you want to make a shortcut letter.  Often it is at the beginning such as before the F in File or S in Save., but it can be used anywhere in the menu item.
(5,190 Views)
Thank you for the response,
I am still in the process of adding a 'Recent Files' submenu from the File menu.  I wanted to display the FULL path to any files that the user recently opened. For example:
File -> Recent Files
Would display the full path, whatever that might be ( including any "_" characters ), such as these belo
C:\Program Files\Project1\Test2_2.INI
C:\Program Files\Project1\Test3_1.INI
I noticed that LabVIEW somehow gets around this,  if open a VI with a "_" character the correct filename is displayed in the 'File->Recent Files' submenu.
How do they manage to do that?  Is there some escape character for underscores? Smiley Surprised
My current workaround is to replace all "_" with "~" when displaying the item in the menu and then reversing the process when the user selects the file to display.
PH
(5,176 Views)
I found that if you add "__"  ( two underscores) for the first underscore it will resolve to display just one "_" in the ItemName displayed in the menu.    So my logic will have to read an INI file, where I keep the list of recent files opened, replace the first "_" with "__" and set this as the actual ItemName in my Recent Files menu.
When a user selects a Recent Files menu item, I will have go back the opposite way to change "__" back to "_" in the ItemName selected.
Smiley Very Happy
PH
(5,164 Views)
