Menu Ring Stops My DAQ!
LV users smarter than I,
I have developed a UI that programmatically places cluster controls neatly on a tab control page.
The same tab control page also has a few XY Graph controls.
Within each of the clusters are the following:
String Control - Contains the channel name
String Control - Contains the "units" of the channel
Numeric Control - Contains the data value of the channel
String Control - Contains the timestamp value of the channel
Menu Ring Control - Contains a list of available plots upon which data channel will be displayed.
I am using Control References to position and populate the values of the controls programmatically.
All of this works fine.
However, whenever I have my test system running, If I mouse click on one of the Menu Ring Controls (which then pops up the list of options), my data acquisition stops until I make a selection or click outside the selection box.
I realize that I haven't explained anything about my data acquisition and where it is going on, but I don't want to overwhelm this post out of the gate.
So here are the major details.
I have multiple DAQ VIs (one for each type of DAQ equipment) that are all reentrant and called via Invoke Node.
They feed a queue.
There is a queue consumer which sends the data to a TDMS file; within this queue consumer is a subVI which displays all data live and contains everything mentioned above.
So, I don't understand why my Invoke Nodes are failing to execute while I have my Menu Ring selected.
I have come to understand that LV multitasking can sometimes cause these types of issues but how in the world do I troubleshoot?
Help!
Chris
P.S. Attached is a photo of the UI for reference. This may clear up some of my rambling.
(2,786 Views)
To clarify, are you saying that the Invoke Node doesn't execute when the menu is visible, or that a VI that is already running (launched through an Invoke Node) pauses when you click on a menu?  If the former, this is a known issue due to the way LabVIEW is structured and I haven't seen a good workaround.  See similar issues
http://forums.ni.com/t5/LabVIEW/droping-down-menu-pauses-program-at-open-ref/m-p/502803
http://forums.ni.com/t5/LabVIEW/Accessing-pulldown-menu-halts-VI/m-p/1109450
http://labviewwiki.org/Lessons_learned_from_plugins
http://lavag.org/topic/1386-cannot-instanciate-new-vi-when-the-root-loop-hangs/
(2,770 Views)
