Menu
Hello Everyone
               I m using Labview.I had a doubt in Menu Bar.I explained Now actually i insert the login and logout in Menu Bar after i login the login should be disabled and then Logout should be enabled
Jai
Jayavel
(4,716 Views)
in fact, i'm not sure to understand your problem : could you join a screen shot of your problem//what you would like to implement ?
Message Edité par ramses64 le 02-16-2009 02:23 AM
V-F
(4,707 Views)
Accepted by Jai2K12
Hi jack,
You can disable the Menu item (Login) using Set Menu item info.
Rgds,
Venky
(4,699 Views)
PLEASE do not post bitmaps. Your ~1MB bitmap could have been saved as a PNG that's only a few kB. AND, changing the extension does not "magically" change the file format. If you changed the extension just so you could get past the upload, perhaps you should wonder why the forum doesn't allow bitmap uploads in the first place.
(4,660 Views)
(2,444 Views)
