MenuStrip font size
Does anyone knows how to change font size in the MenuStrip?
I want to replace standard LabVIEW runtime menu with .NET MenuStrip to have a posibility to make it bigger and more suitable for touchscreens. MSDN said that MenuStrip has a font property which "Gets or sets the font used to display text in the control" but it looks like read only property (I'm unable to change it to write)...
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
Message 1 of 10
(7,034 Views)
Hello bienieck,
I checked in LabVIEW 2016 and everything seems to work fine for me. After Creating MenuStrip via Constructor Node, I place Property Node (.NET), choose property Font, right click on the property name and I can Change All To Write.Write Property
Message 2 of 10
(6,966 Views)
Instead using the menu strip, maybe you could increase the size of the font of the Labview runtime menu (not that much, because the menu has a determined height) with the key:
SystemFont="Arial Unicode MS" 30
in the application.ini
Message 3 of 10
(6,956 Views)
@Martiko wrote:
Hello bienieck,
But then, can you put in example "size" property and change it to write?
Michał Bieńkowski
CLA, CTA, CPI
Message 4 of 10
(6,930 Views)
I tried this but I feel like it is not very elegant and it is not customizable enough.
Michał Bieńkowski
CLA, CTA, CPI
Message 5 of 10
(6,929 Views)
Accepted by bienieck
@Martiko wrote:
(...) I checked in LabVIEW 2016 and everything seems to work fine for me (...).
Hi bieneck,
It seems to be working with "Size" exactly the same as with "Font" for me.
MenuStrip Size to Write
May I help you any further?
Message 6 of 10
(6,923 Views)
Oh, you were right. I thought that I need to use it this way:
And this way I can't change "size" to write.
It seems that I just don't know how to use it 🙂
Michał Bieńkowski
CLA, CTA, CPI
Message 7 of 10
(6,913 Views)
This works for LabVIEW 2024. Thank you.
Message 8 of 10
(949 Views)
When Application Builder creates an executable, it also creates two additional files; one .ini file and one .aliases file
Edit the Application.ini file to change the menu font and font size:
Original menu:
Original Application.ini file:
Added one line to the .ini file:
and the menu looks like this:
 This works on LV2024 with menus created using the Edit --> Run-Time Menu... command
Alejandro A
Message 9 of 10
(881 Views)
The menu bar on the front panel is NOT a Windows object.  There is no guarantee NI will 100% honor Windows settings.
Every thing on the front panel (That includes menu bar, tool bar, and scroll bars...  Except the title bar and 10-pixel edge on the left, right and bottom sides) are draw by LabVIEW.
George Zou
Message 10 of 10
(875 Views)
