Menus immediately disapear when i right click
Hi, when i right click on the block diagrom or front panel, the menu appears for a split second and immediately disapears.  The same happens when I try to open the File/Edit/Project/Operate/Tools/Etc menus up top.  I click on them, they pop open for a split second, then immediately disapear.  I just fully un-installed and re-installed LabView and it's still doing it.  Any ideas out there?
(3,360 Views)
Have you tried with a different mouse?  Could be a sticky, clicky mouse problem.
(3,335 Views)
HI
Check you keyboards both Alt key, I think that was get pressed and not released properly.
Because this kind of problem happen if your Alt key  is pressed.
Hope this helps
Regards
Santosh
(3,327 Views)
Exactly!
- Partha ( CLD until Oct 2027 🙂 )
(3,319 Views)
I was hoping that was it, but it is not.  I can right click just fine in any other program, and any other program the menus work fine.  I also hooked up a new keyboard and mouse and the same thing is happening.  I also can not use keyboard controls to do anything.  For example alt+F does not highlight the File menu.
LabView is definately behaving as if a button/key is being pressed constantly, but I can't figure out where it's coming from.
(3,292 Views)
If a different mouse and keyboard did not work, it still does seem like a corrupt installation of LabVIEW. I would refer to the attached document to ensure that a clean re-install of LabVIEW is done. I hope this helps.
Vivek Nath
Applications Engineer
Machine Vision
(3,278 Views)
