Merge Event Refnums
I'd like to have a single event structure registered to both user events and a digital input signal's state change. Is that possible? I don't see a way to "merge" the event registration refnums before the event structure, and when I try to wire one event registration refnum into the other Register for Events VI, it automatically changes the event type to match the existing refnum's event type.
(1,654 Views)
Accepted by jrdwight
You can use a cluster to merge Event Refnums. See below, Bundle the Event Registration Refnums.
EDIT: Wire the cluster to the dynamic Event Terminal on the Event Structure.
(1,632 Views)
Ah, that's easy enough! Thanks, I'm still pretty new to dynamic event registration, so I appreciate the quick help!
(1,619 Views)
