Merge signals and waveform chart
Hi all
I am asking the following since I have little knowledge on labview
I have a merge signals function that should take 7 signal as inputs . but i have no idea how to see the 7 signal  outputs on a waveform chart. i want to display the 7 signals each of them on a waveform chart. (as looking into the front panet i should see one single waveform chart displaying the 7 signals . )
can you help me guys ?
Thank you .
Bill David
(6,930 Views)
Hi Bill,
I think you should definitely try the 'Merge Signals' functino from the Express Palette -> Signal Manipulation.
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(6,929 Views)
zyl7 thank you for the reply .
Yeah I have used this function but i have no idea how to make the 7 signal at the outputs plotted in a waveform chart like you see in the attachement.
Bill David
(6,919 Views)
If you right click your chart, then you should see the option 'stack plot'... It wroks fine me, see pic attached !
(6,914 Views)
Hi Zyl7
I did exactly what you told me . right click the waveform chart then, stack plots .then i changed the number of plots of the waveform to be 7 . but i am still seeing only 1 single signal .
why is that ??? m confused !!
Bill David
(6,908 Views)
Accepted by topic author Bildavid
I'm confused to... Please find attached a really simple VIs which does the job you ask...
Are you graphing in a Graph or in a Chart ? The control in my VI is a chart.
(6,903 Views)
Zyl7
Thank you so much . it was all my fault . it is fine now . thank you so much 🙂
Bill David
(6,901 Views)
