Merge signals in NXG
I've started to using Labview NXG.
For a project i want to display 2 signals in one chart, the raw-signal and a filtered signal at 75 Hz.
In labview 2016 it worked well with "merge signals", but in NXG I dont find the alternative.
THX,
Dries
Message 1 of 8
(3,694 Views)
Hi Dries,
Well, in LabVIEW2016 you could use a BuildArray node as well, no need for ExpressVIs here.
Does BuildArray exist in NXG too?
Message 2 of 8
(3,690 Views)
I can confirm that Build Array exists in NXG and can be used to display 2 signals on one chart
Message 3 of 8
(3,644 Views)
Strange in my application it doesn't seems to work 😞
I putted my code in attachement.
Dries
Message 4 of 8
(3,638 Views)
Hi Dries,
what's the error message?
And why do you attach (just) an image instead of your VI?
Message 5 of 8
(3,633 Views)
Hi GerdW,
In attachement you find the errorcode. I can't upload the gvi, it is blocked by the forum.
In fact i started with the example "Automate Saving and Reporting Data".
Kind regards,
Dries
Message 6 of 8
(3,627 Views)
Accepted by topic author DriesD
Hi Dries,
in "old" LabVIEW one could change the operation mode of BuildArray to "concatenate": it seems you need to do that too!
Well, you can always attach ZIP files…
Message 7 of 8
(3,623 Views)
GerdW,
I found a concatenate checkbox and... it seems to work.
I just have to test it with my DAQ, but the error is gone.
Thx
Message 8 of 8
(3,621 Views)
