"Get Exported File Path.vi" LV2018 vs. Lv2013
Moving a large project, with an RT part, from LV2013 to LV2018.
Mostly went without a hitch, but do have a snag here.
On the RT side there is an "addon" which is a separate PPL, compiled separately from the main program, and can be "plugged in" without recompiling the main.
Works fine in LV 2013.
But it fails on LV2018.
Here is some code, with probes from LV2013.
Note that the result (probe 4) is a fully formed path to a file within an LVLIBP.
Here is the same code, with the same probes, from LV2018:
Note how probe 4 shows BLANK, which leads to a FILE NOT FOUND error, and failure.  The file is definitely there, the INPUTS to "Get Exported File Path.vi" are the same, but the result is blank.
Any ideas?
Steve Bird
Culverson.com
LinkedIn
(3,225 Views)
Is LVOOP used in the Addon ?
If so...
Spoiler
chase down into all of the VIs that use LVOOP and look for a class constant that looks to be grayed-out. Put it in a diagram disable structure and drag a new instance into the diagram to replace the funky instance.
Spoiler
In a forum I can not link in public some have found that situation that drove me nuts the first time I encountered it. It was screwing up my error reporting functions used on a RT system and was preventing me from getting error reports on the Windows side of the application.
Spoiler
I do not think there is a fix for that yet. There was some talk about the default value of the Class was not empty or whatnot.
Otherwise ignore this post.
Ben
(3,210 Views)
Is LVOOP used in the Addon?
No.  It's used elsewhere on the RT side, but not in the addon itself.
Steve Bird
Culverson.com
LinkedIn
(3,178 Views)
Perhaps the rules have changed.
I am constructing the VI NAME to open by qualifying it with the library name and a colon.
i.e. probe 3 is "3C05A786 RTAC Addon for Barometer.lvlibp:RTAC Addon for Barometer.vi"
That was necessary in LV2013 - it says so in my comments, because it said so in the help somewhere.
If I DO NOT qualify it (i.e., simply ask for "RTAC Addon for Barometer.vi") in LV2018, it seems to work.
Steve Bird
Culverson.com
LinkedIn
(3,177 Views)
Hi Steve,
How would it affect your workflow if you used the "RTAC Addon for Barometer.vi" instead of qualifying it with the library name?
DillonL.
(3,155 Views)
No problem, but it was my understanding that it was NECESSARY to qualify it in LV2013 - that's why I did it.  I'd like to have one set of code that would compile and run both ways.
Steve Bird
Culverson.com
LinkedIn
(3,128 Views)
It was.  Now LabVIEW fixed that.
(3,124 Views)
