Merging two or more unique strings
After I finish excuting testonly.vi I go into mergstrings and check the values; If I open mergstrings.vi then excute you testonly.vi I see the values in string 1 and the output string.
Thank you for the attachment I am looking at it as we speak.
Message Edited by MrSafe on 08-13-2008 02:24 PM
Message 21 of 25
(997 Views)
Hi MrSafe,
LabView doesn't store values in indicators when the front panel is closed (to express it in a simplified version).
That's why you don't see new values in mergstring.vi when you open it after executing testonly... In LabView the wire is the variable, not the control/indicator!
Message 22 of 25
(993 Views)
correct me if im wrong but from what you said Labview has the values it simply doesn't show it in the current method I am using?
Message 23 of 25
(990 Views)
Hi MrSafe,
yes, when opening a vi after execution you will not see the last values! Instead you will find default values...
Either set the subvi to open the panel when executing (in the vi properties) or (better option) use a wire as I said before and have shown in the attachment!
Message 24 of 25
(987 Views)
Thank You. I apologize for asking this obvious questions I will continue to read toturials but I am more of lets try and put it to the test type of person where I can fallow the guide as I am doing it on labview. Hands on.
Message 25 of 25
(975 Views)
