Message "fpsane.cpp" line 269
I get this message when I try to save or find problems with program. After I hit the ok button 10 times it comes to failure screen and then shuts down.
(3,171 Views)
Robby,
This error is related to what LabVIEW refers to as an 'insane object.' These errors, along with some possible solutions, are discussed in the following Knowledge Base article:
Knowledge Base 1F398NU0: What Does an "Insane Object" Error Mean and What Should I Do?
I recommend looking through this article and trying the various solutions listed there. Also, it appears that there was a bug in LabVIEW 6.0.x that caused these types of issues. If you are using this version of LabVIEW, you may want to consider upgrading. LabVIEW versions 6.1 and later have fixed this issue.
JohnM
(3,171 Views)
