Meter numeric indicator
I have several numeric meter indicators on my UI and I have digital display enabled. The problem is that the needle pointer doesn't work in all the indicators. Only the needle in the first indicator works but all the digital displays in all the indicators read the correct values. Please see attched screenshot of the front panel. Does any one know how to fix this problem?
(3,426 Views)
If you're talking about the two with the large negative values, 0 is as close as the needle can get.
If that is not the problem, we need to see some code.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,418 Views)
