Waveform chart update time
Hi all,
I have a VI with one while loop that generates an array of measurements at a specific rate (to simulate the acquisition rate of an FPGA I am interfacing with). A second loop displays the data in a chart and records it to a file. I am using queues to transfer the data between the two loops. The simulator generates 10,000 points every second, this cannot be changed (see VI).
I need the chart to update more often than once per second, which is what it is doing now. By that I mean more fluidly, so it looks like data is just running across the chart rather than chunks being added to it. It does not need to be real-time.
I know the problem is that the waveform is added to the chart 1 second/update, but I'm not sure what the best way of fixing it would be. I tried the resampling VI but it still updated the chart once every second.
The VI is attached.
Any help in solving this would be appreciated.
Ilya.
(4,212 Views)
The graph is updating once a second because that is how often you are passing data to the queue that the driving the chart.
A more basic problem is your expectations. You are not going to send 10000 points to a chart every second and get something that scrolls "fluidly".
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,191 Views)
You may need to break the waveform into smaller chunks after the queue, and drip feed it via another queue to a display (chart) loop, that reads it at, say 10 Hz. You may be able to use the #elements in queue to programmatically adjust the timing of this loop to just keep up with incoming data.
(4,187 Views)
Yes, you could do that, but the basic problem remains that updating 1000 points at a time will not give a fluid display.
Mike...
LabVIEW Champion
(4,184 Views)
