Metric String to Number
Does there exist a way to convert the string "1ms" into the number 0.001?  Same with the µ (micro), k (kilo), M (mega) and any other metric symbols?  I can do this manually no problem but I thought someone may have done this already.  Thanks.
(4,371 Views)
Accepted by Hooovahh
%p my good friend.
(4,365 Views)
try that one with '1ms' as the input as the original post stated.
(4,353 Views)
Yes there is a limitation,  Nothing a regex can't handle.
(4,351 Views)
Yes I noticed that right away but in this case I can simply the last char.  Glad it is so simple.
(4,343 Views)
It will be easy as soon as NI fixes CAR 425562...  I've ran into this enough times.  I ended up putting in spaces between the prefix and the unit to get the Scan From String to work properly.
(4,326 Views)
