Micro-Nuggets !!! ~~~~ Post 'em if you got 'em
Thank you Richard,
Sorry for my ignorance. I have read this thread and in an excitement(I hope every first time user of LV feel the same) , typed my first reply here. I will consider looking in depth next on.
Message 291 of 368
(2,337 Views)
@DhruvAcharya wrote:
Thank you Richard,
And even with the ancient LabVIEW versions that support VISA (very old VISA like whatever shipped with 6.i) You could use "Tools>>Options :Environment- check the box for "Automatically Close VISA Sessions" and VISA sessions will close when the top level VI goes idle.
Welcome to the forums!
Message 292 of 368
(2,297 Views)
I don't know about anyone else, but I was recently looking for a way to centre a VI in a subpanel and couldn't find anything. In my particular case I had a little spinning 'loading' indicator VI and wanted to have it centered in the subpanel it was loaded into.
This is the way I did it:
1) Centered my VI's front panel around the origin:
2) Create an event handler for the Pane Size event with the following:
When my VI is inserted into the subpanel or the subpanel/pane resizes (e.g. change window size) - the origin remains in the centre of the pane.
I found this very useful for when you have a resizeable user interface!
(blog)
Message 293 of 368
(2,183 Views)
Curious why you couldn't do "left minus right" and "top minus bottom" instead so you could avoid negating the answer?
Bill
CLD
(Mid-Level minion.)
Message 294 of 368
(2,176 Views)
Yes, good point - I suppose I had better post this is in the rube goldberg code thread as well Smiley Very Happy
(blog)
Message 295 of 368
(2,172 Views)
Ehhh... I've done worse.  😉
Bill
CLD
(Mid-Level minion.)
Message 296 of 368
(2,166 Views)
You might also want to try Quotient & Remainder instead of the Divide in order to avoid some of the data coercion.  Or, since it is a divide by 2, use a a Logical Shift (would be less processor intensive if you are really going for any and all performance gains).
Message 297 of 368
(2,147 Views)
I can't think that unnecessarilly flipping two sign bits would quite qualify.  Mr. Goldberg would be very disinterested in the wasted energySmiley Very Happy
Message 298 of 368
(2,131 Views)
From a performance standpoint i agree, from a fanatic standpoint it's an extra block that's not needed (like when people wire a '0' constant to an Index array). The RGC is less than minor, thus a micro Rube, far from a slap on the wrist.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 299 of 368
(2,116 Views)
Using the negate is better than simply dividing by minus two....
Message 300 of 368
(2,092 Views)
