Microsoft Outlook Question
I have used the outlook ActiveX VI's which can be found on this board to send email from Labview.  Each time I send an email I recieve the following message.
A application is trying to automatically send an email on your behalf.  I believe this is related to the security included in the recent versions of Outlook.  I am using Outlook
2003.  Is there a solution to allow Labview to send an email without interaction from the user in Outlook.
Clark
Message 1 of 26
(10,396 Views)
There are security settings for Outlook that are controlled by your Network Administrator.  You will have to ask them to allow another program to send the email.  I believe that there is a knowledge base on ni.com or microsoft.com that covers this.
Message 2 of 26
(10,369 Views)
Thanks for your help.  I am using a local install of Outlook, but can't seem to find where I can changes these settings.
Clark
Message 3 of 26
(10,358 Views)
If I recall, they were only on the Outlook mail server.
Message 4 of 26
(10,355 Views)
Hi Clark,
As stated above this is almost certainly an issue with the security settings in Outlook.  I did a little research on the Microsoft Office web site and found this document: http://www.outlookcode.com/d/sec.htm  which discuss the email security in Outlook.  I think that you will find information on disabling this error message here.
If you would like to do a little more research, I found the Microsoft Community fairly helpful: http://www.microsoft.com/office/community/en-us/wizard.mspx?lang=en&cr=US&cat=en-us-office-outlook&p....
Good luck!
Megan B.
Message 5 of 26
(10,329 Views)
Thanks again for the insight.  I'll take a look at some of these and see If I can apply them to Labview.  I have located a fix by using the program express click yes.  But I am a little concerned about the security risks that this may lead to.
Thanks again.
Clark
Message 6 of 26
(10,328 Views)
Is there a particular reason for using Outlook? A company name OstroSoft makes an ActiveX SMTP Component that is very slick, easy to use and free--and they aren't the only ones...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 7 of 26
(10,144 Views)
Would anybody have a vi that allows labview to send an email by means of an Email software packages (i.e. Microsoft outlook for example)
Message 8 of 26
(10,189 Views)
Message 9 of 26
(10,164 Views)
Thanks for example.
I am unable to run the VI. I am getting the following errors:
Property Node: Invalid Property
Property Node: Invalid refnum
Invoke Node:     Invalid refnum class
Invoke Node: Invalid method
I am using Labview version 7.0
Message 10 of 26
(10,152 Views)
