Microsoft Outlook Question
These property nodes refer to the ActiveX calls.  You will need to configure them for whatever version of Outlook that you are running on your machine.
Message 11 of 26
(4,721 Views)
I want to send mails using my Lotus Notes, its the only thing configured on my (in fact everyone's) machine.
I am using : SMTP Email Send Message.vi and getting the error as { TCP Read in SMTP Email TCP Read xTP Reply.vi->SMTP Email Command.vi->SMTP Email Open Session.vi->SMTP Email Send Message.vi->send mail.vi } error code 66... since I am very new to these mail sending concepts, I would like to know
1. if I should keep my lotus notes ON/OFF while performing the operation
2. and secondly, what are the settings that I need to take care so as to send my mails properly
Message 12 of 26
(4,522 Views)
1.  You don't have to have Notes open.
2.  Get the right mail server name from your IT staff.  Use that for the 'mail server' input of the VI.
-Khalid
Message 13 of 26
(4,512 Views)
I wanted to jump into this topic. I have been trying on and off to do this for about a year and cannot get it to work, I have verified that the name is correct. I know because I can telnet into the server and because when I run the example vi it shows the connection to be OK. But when I go to send a message I get an error 500 saying invalid command unrecognized command. any suggestions.
Joe.
"NOTHING IS EVER EASY"
Message 14 of 26
(4,505 Views)
Hi Khalid,
Thanks for the suggestions. The first one is fine. In case of the second, I have talked to our IT dept who say that it must be getting blocked because of firewall or some other network congestion. Don't know exactly where the blockage is happening. Will get back if I happen to get thru the our firewall.
reg
sreedhar
Message 15 of 26
(4,489 Views)
"These property nodes refer to the ActiveX calls.  You will need to configure them for whatever version of Outlook that you are running on your machine.  "
Just exactly how do you do that? I have Outlook Express Ver 6.
Message 16 of 26
(4,404 Views)
how to get the Vi provided above to send with attachment?
thanks
Message 17 of 26
(4,274 Views)
I'm not sure what you are asking.  Please ask it in a different way.
Message 18 of 26
(4,260 Views)
oh, sorry
I tried the Send Email Sub.vi which some one posted earlier and just wondering how to make it to send with an attachment. I am using LV6.1 so there is a limmitation of functions and Help section. I knew some later versions of Labview have function to send email and such.
Message 19 of 26
(4,249 Views)
You're almost there! In the Mail Item property node you'll see a property called Attachments, which outputs a refnum. Wire that refnum into an invoke node and select the Add method as shown below. I haven't tested it, but something very similar should work just fine for you.
Message Edited by Jarrod S. on 04-21-2006 01:57 PM
Jarrod S.
Message 20 of 26
(4,230 Views)
