Min & Max bug?
Hi all,
I have observed strange behavior in the min & Max node in the snippet below. It is set to compare elements. Depending on the array size as determined by "Dimension" the resulting y array for "Signal" yields different results.
It is supposed to read:
NaN,1,1,1,2,2,2,NaN,...
But when I enter a value for "Dimension" of 16 or greater it reads:
NaN,NaN,NaN,NaN,2,2,2,NaN,...
For smaller values of "Dimension" the snippet works as intended.
Using probes it seems that min(NaN;x)=x for Arrays with 15 elements and less and for larger arrays it's min(NaN;x)=NaN
Surely this is not intended
I guess I'm missing something obvious and am about to learn something. Smiley Happy
Or is this really a bug?
Using LV 2011 SP1
Regards
Florian
Message 1 of 9
(4,689 Views)
Hi Florian,
such a bug has been reported before. It gives wrong results for arrays with a certain size (16 elements minimum)...
Sorry, too lazy to search this in the forum on my own. 😉
Message 2 of 9
(4,679 Views)
Thanks for answering.
I did a quick forum search before posting, and have tried again (with more effort Smiley Wink) after reading your post.
I can't find anything though.
Nothing here
https://www.ni.com/en/support/documentation/bugs/11/archived--labview-2011-and-2011-sp1-known-issues...
either.
Regards Florian
Message 3 of 9
(4,670 Views)
Hi Florian,
I too can't find that at the moment. But I remember some strange compiler problems for arrays of certain size (16 elements was the "barrier" I think).
Maybe someone else can remember the corresponding CAR or link...
Message 4 of 9
(4,644 Views)
For what it's worth it's doing it in LV2012 also.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 5 of 9
(4,629 Views)
Accepted by topic author Florian.Ludwig
A workaround for your problem is to put a for loop around the compare.  It will give consistent results.
What I find interesting is that the result for arrays larger than 16 elements is the same as if you compare aggregates.
This also appearss to be specific to NaN.  If you use a different value for your array, you don't see the value change.
I can also confirm the same behavior in LV2012.
Message 6 of 9
(4,624 Views)
that's the workaround that I came to implement too.
Regards Florian
Message 7 of 9
(4,620 Views)
Just tried it in LV2009 also and it worked as expected.
Mike...
LabVIEW Champion
Message 8 of 9
(4,608 Views)
This has been reported and has a new CAR #385324.
Mike...
LabVIEW Champion
Message 9 of 9
(4,566 Views)
