Min & Max frequency of a waveform in LV 7.1
Darn it! I made a mistake the analysis is not made on the corrected valleys. Can you take a look at the picture and correct the mistake
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 21 of 27
(1,371 Views)
yes, I saw
you were not feeding the multiply node with the unbundled'locations'
got it
Lawrence M. David Jr.
Certified LabVIEW Architect
cell: 516.819.9711
http://www.aleconsultants.com
larry@aleconsultants.com
Message 22 of 27
(1,364 Views)
On my way home, the train get stuck, so I killed some time by using the zero crossing method on the data. As you can see the gain is not very big. But it is somewhat less jitter. I guess jitter are caused by AD resolution. With better AD resolution you will probably get more accurate readings hence less jitter. Better resolution can be achieved by using more of the full AD converter span ( if possible ). Or increasing the AD resolution by changing to an AD converter with more bits. But this is cost/benefit problem. If the costumer is happy just leave everything as it is 😉
Message 23 of 27
(1,344 Views)
Spoke to the client yesterday and explained the issue. He was real apologetic, Says he always runs the data through a Butterworth low pass filter before working with it but he sent me raw data.
Ran it through the filter before doing the peak analysis - it looks great
thanx for all ur help
when you are in NY I'll buy you those beers
cell: 516.819.9711
Message 24 of 27
(1,342 Views)
Take a look at this.  This uses the equation to determine the instantaneous frequency (derivation of the phase).  It's noisy, but it does work pretty well.
Randall Pursley
Message 25 of 27
(1,327 Views)
with a lowpass filter in the front, you wouldn't even need to decimate and average to reduce the noise.
Randall Pursley
Message 26 of 27
(1,310 Views)
Since I can't save back to 7.1 here are screenshots of FP and BD
Randall Pursley
Message 27 of 27
(1,293 Views)
