MisMatch when UnFlattening
@Sam_Sharp wrote:
@Intaris wrote:
But then I can't quite follow where the Strings are supposed to be.....  I don't see Hex values for "degC" Anywhere in the flattened string (And certainly not twice).   If I had to hazard a guess, I might suggest that the cluster V1 has some hidden elements in the cluster..... It seems to be storing a couple extra DBLs with zero value.
The units could be an Enum rather than a string?
Just posted the exact same theory.  I reckon so.  If so, then the flattened string seems to check out (for me, I used to parse these in the past.  I don't remember why, perhaps just out of interest).
Message 11 of 33
(1,795 Views)
@CoastalMaineBird wrote:
 the array should be in-line.
Which is what I expected, but that contradicts what Norbert said above.
It is inline, Norbert is mistaken I believe.
Try adding "01" at the end for a Boolean TRUE and "4059 0000 0000 0000" for a DBL "100" and see if it will cast back then.......
Message 12 of 33
(1,789 Views)
The data elements before Scale Factors is not an issue because if V2 wouldn't match them, all elements AFTER Scale Factors would also mess up (e.g. Rec. Rate) as data alignment wouldn't fit anymore.
Good point.  It CORRECTLY unflattens items AFTER the array, proving that it hasn't gorched the unflattening process.
That assumes that the default values of V2 don't by accident match what we see in the screenshots....
No, all defaults are 0/false/"", It is CORRECTLY handling stuff after the array.
One VERY IMPORTANT ASSUMPTION: The tab order of elements of V1 and V2 is identical. So the two new elements are placed AFTER the other items (including the array)!. Is that true?
--- I don't know about the tab order, but the cluster order is indeed that way.  I deliberately added new elements AFTER all others, thinking that it would just leave them default.
FWIW, it does complain about "Data is corrupt" (error 74) in the second case.
Steve Bird
Culverson.com
LinkedIn
Message 13 of 33
(1,785 Views)
Sorry - that is an ENUM, which only occupies 16 bits.
Steve Bird
Culverson.com
LinkedIn
Message 14 of 33
(1,783 Views)
Yes, it works, without error.
The original:
After adding the appropriate data:
Still, I don't understand.  How does adding the data onto the end, make the array start working?
Steve Bird
Culverson.com
LinkedIn
Message 15 of 33
(1,771 Views)
UGLY HACK:
Unflatten with the new TypeDef
If Error
   Unflatten with old TypeDef
SON OF UGLY HACK:
Append 0x01 4059 0000 0000 0000 to every string
UnFlatten with new TypeDef
(If the string already has the new data, the excess will be ignored.)
Steve Bird
Culverson.com
LinkedIn
Message 16 of 33
(1,764 Views)
You would have to read the relevant help section on how LV stores data in memory, but my guess is that the array is stored as a pointer (which makes more sense than being flat, as it allows LV to resize it cleanly and handle internal types) and when the unflatten fails, LV simply doesn't get to the point in the code where it puts the correct pointer in the cluster (or something else along those lines), resulting in the array being empty.
The bottom line is that you should not use this. Use something like the OpenG VIs.
___________________
Try to take over the world!
Message 17 of 33
(1,749 Views)
I disagree. The bottom line for me is this is a bug.
Message 18 of 33
(1,744 Views)
None of that applies to how things get FLATTENed.
Steve Bird
Culverson.com
LinkedIn
Message 19 of 33
(1,731 Views)
You say the problem happens when unflattening. That's a conversion from a flat format to an in-memory representation.
___________________
Message 20 of 33
(1,722 Views)
