Mismatched versions of Labview and PDA Module
Last spring we received the update of labview 8.2 to 8.2.1 and we bought labview PDA 8.2.1. We installed the whole this week. When I try to run\build the VI, the error "Mismatched versions of Labview and PDA Module" appears.
I looked on the forum and found a similar case but it updated Labview and LV PDA. I never had LV PDA 8.2. I try to install LV PDA 8.2.1 with LV 8.2 but it is impossible because it is not the same version.
Do you have an idea of the cause of the problem?
Thanks you!
(6,200 Views)
You will have to install LV 8.2 first then update it to 8.2.1.
Reboot your PC.
Install the LV 8.2.1 PDA toolkit (know that the toolkit also requires some other programs, mainly MS ones).
This should work.
André
André (CLA, CLED)
(6,189 Views)
