Missing LKREALT.dll
(3,313 Views)
It should be in C:/Windows/System32 folder - what NI products do you have and with what serial numbers?  Can you verify that it's not in that directory?  Was it manually removed by accident?  I don't have authorization to simply post it, but if you go through your local sales person, they should be able to authorize an engineer to send it to you after confirming you should have it on your system.
Best Regards,
JLS
Best,
JLS
Sixclear
(3,304 Views)
Thanks for the feedback.  I think I figured it out:  I deployed-downlaoded the smaller 8.0 runtime engine.  It need to be the bif 8.01 runtime to insert the proper dll's in the wndos director.
(3,302 Views)
That makes sense - thanks for the update!
Best Regards,
JLS
Best,
JLS
Sixclear
(3,298 Views)
