Missing M530DLL.dll for Newport Power Meter 2935 and LabView
I have installed all the software and drivers with the Newport 2935 and when I try to run the included VI, I find that I am missing the file M530DLL.dll.
(4,630 Views)
There is no driver for the 2935 available from NI. If you got the driver with the instrument shouldn't you be asking Newport?
(4,601 Views)
I sent Newport an email, but I'm not sure if this is part of the power meter package or the labview software, or something different altogether.
(4,592 Views)
Accepted by topic author keony31
Did you even go to Newport's web site? I just did a quick search there and found  this
(4,585 Views)
Wow thanks a lot!I haven't tested it, but I believe this fixes the problem.
I did spend a good amount of time on the newport website, as well as google, trying to find if a solution and didn't come across this.
Thanks again for your help Dennis!
(4,580 Views)
I went to the address above and could not find the answer. I found a direct link to get the DLL here though.
ftp://download.newport.com/Photonics/Power%20Meters/Current/x935_x931_1918-C_%20Inst%20CD/Others/Mis...
At the time I am writing this newport is going through some website changes. It was not easy to find.
Hope others find this helpfull
(3,927 Views)
