Missing USB VISA Resource
I have just started configuring a new installation of LV 2016 on a Win 10 machine. I have a USB 6501 plugged in. It shows up in IMAX and the Device Manager. When I open a VISA Resource control on a LV front panel, the device is not shown in the pull down menu. I apologize if this is common  but I have little experience with USB instruments. I would appreciate some help.
(4,004 Views)
For that you have to install a NI VISA driver, that's here https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7tJSAS&l=en-IN
(3,998 Views)
Driver installed, Version 19, I believe.
(3,992 Views)
Hmm.....I just checked it on another machine with Win 7  and I get the same result so I must be doing something wrong. I am using a plain vanilla VISA Open VI and creating a FP control. I also checked the VISA Alias list in IMAX and it is not there but shows up in the IMAX hierarchy as "Dev2". I have Resource Names for some other GPIB-USB instruments that are installed and I am able to run them correctly. It's just the 6501 that is not showing up in LV.
(3,988 Views)
Accepted by yikes
Thanks for the help. The 6501 is under the DAQ umbrella not VISA. Device Name not Visa Resource.
(3,944 Views)
