01-02-2009 03:34 PM
Hi, I've recently been tasked with updating some old LabView 5.2 files to 8.6. In order to do this, I first had to get an evaluation copy of 8.2.1 by calling tech support so that I could save the 5.2 files in a format that is readable in 8.6. However, when I opened the files I was told by the (8.2.1) software that the following VIs are missing: AI Hardware Config.vi, AI Config.vi, AI SIngleScan.vi, DIO Port Write.vi, and DIO Port Config.vi. After much searching and after contacting tech support again, I found that these should be available after installing the NI-DAQmx 8.7.2 driver which I did. However, I still cannot seem to find these library VIs. I've read a few message board posts from people looking for these files but their problems seem to be fixed after they install the NI-DAQ driver. I'm very new to LabView (I just found out what it is earlier this week!), so simple instructions would be appreciated if you guys can help me out.
Thanks, Gabe
Solved! Go to Solution.
01-02-2009 03:50 PM
You installed the incorrect driver. They are not part of DAQmx. They are part of what is called the traditional DAQ driver. This is included with your LabVIEW distribution but not installed by default. You can also download the driver.
01-02-2009 04:33 PM
01-02-2009 05:03 PM
01-05-2009 08:34 AM
Exelent, the missing VIs were actually in the \National Instruments\LabVIEW 8.5\vi.lib\Daq\ folder since I'd upgraded from 8.5 to 8.6. For anybody else reading this thread later down the road, I guess it's also important to note that the VIs are contained in the .llb files so you can't just search for them through Windows. To be specific, I found AI Hardware Config.vi in zadvd.llb and AI Config.vi in the AI.llb file.
Thanks again for all the help Dennis.
08-24-2011 03:53 AM
I just had the exact same problem and this has fixed it for me in no time........
thanks!
