Missing file in a application builder
I try to make a stand-alone application with the application builder of LabVIEW.
My problem is that a file seems not to be present (see picture PB.jpg) when I launch the the executable whereas the installer is executed without problem.
When I build the installer, I can see the missing file in the list of subvi to build (picture appli_builder.jpeg).
I build this installer on a PC under Windows 2000 and I install it on an other one under XP. Could it be the reason of the problem?
thank you.
Vincent
(2,846 Views)
Hi Vincent,
I think you have not install NI-DAQmx driver on the target PC, when you create the exectuble (or installer) you need install the driver on the other pc.
Christophe S.
Account Manager East of France І Certified LabVIEW Associate Developer І National Instruments France
(2,819 Views)
