04-20-2006 07:51 AM
04-20-2006 08:12 AM
This is actually a good thing IMO, because it allows you to have a standard size and standard wiring schemes (top is for references, bottom is for errors, etc.) and to add more controls later if necessary. Also, the 4-2-2-4 pattern is a good one and is the one of choice for most users.
If you still want the old behavior you can add the line DefaultConPane=-1 to your labview.ini file, but in any case it's advisable to leave extra connectors in case you will want to pass more information in the future without breaking your code.
04-20-2006 08:40 AM
04-20-2006 09:42 AM
04-20-2006 10:23 AM - edited 04-20-2006 10:23 AM
Check out my weekly nugget here to find out how to get the numeric values of the different connector pane patterns. Remember that this functionality only applies to LabVIEW 8.0 and later.
-D
Message Edited by Darren on 04-20-2006 10:24 AM
04-21-2006 03:38 AM
