Missing measurement entries for DAQMx
Hi there, in my program a small error occurred.
The following error occurs in all exported files:
LabViewBug.PNGWith the defined task I get all 0.004 seconds 3 values from 3 different physical input channels.
Exactly one second, the time series jumps to another interval. The error occurs only on exactly one second. In the second (2, 3, 4...) The error does not occur!
Does anyone have an idea what problem that can be?
Thanks!
Message 1 of 9
(4,140 Views)
How is the task defined?  As Continuous Samples or N Samples?
Message 2 of 9
(4,126 Views)
Oh, sorry for this missing Information.
It is defined as continious.
Message 3 of 9
(4,123 Views)
Okay.  I was thinking that if it was N samples, a small Windows hiccup might cause you to miss some milliseconds worth of data.  Continuous should work since it keeps the buffer going and the data should be there in the event of delay.
Attach the actual VI so we can see what some of the values you have in the controls.
Message 4 of 9
(4,119 Views)
Here is the current Version of the Vi
Message 5 of 9
(4,112 Views)
Accepted by topic author JohannesS93
It looks like you are clearing the task after every iteration, so it needs to make a new task each time.
  1. Create task outside loop
  2. Clear Task Outside loop
  3. Only read samples inside loop.
mcduff
Message 6 of 9
(4,095 Views)
Good catch.  I completely missed that.
That would effectively kill the positive things about Continuous Samples.
Message 7 of 9
(4,084 Views)
@RavensFan
Everybody misses an "extra point" every now and then. Smiley Wink
Message 8 of 9
(4,081 Views)
@mcduff wrote:
@RavensFan
Oh nooo!!!   Too soon!
Smiley SurprisedSmiley LOL
Message 9 of 9
(4,072 Views)
