12-18-2012 02:50 PM
According to the Help, it must be there
"Select Tools»Compare»Compare VIs from the front panel or block diagram menu of a VI"
But it is not (see the screenshot attached).
Using LabVIEW Full Development System 2011 SP1
Why?
12-18-2012
03:01 PM
- last edited on
02-03-2025
07:28 PM
by
Content Cleaner
Compare VIs requires the professional system. Full is not enough.
Quote from this page :
"Note The Compare VIs dialog box is available only in the LabVIEW Professional Development System."
Compare features here.
12-18-2012 03:23 PM
thank you
12-18-2012 03:25 PM
That being said, I think a case could be made to include this core functionality in all levels of LabVIEW.
For a text programming language, anyone can do a diff on two text files. It is a very basic functionality.
The usability of LabVIEW as a full featured programming language is crippled if code comparison is not part of the basic tool set. Maybe I'll write it up as in idea.....
07-01-2021
08:32 AM
- last edited on
02-03-2025
07:29 PM
by
Content Cleaner
Quote from this page:
Sadly, with a software lease the full development is automatically activated.
Activating the pro isn't a problem, but you have to do it.
And when renewing, the professional license seems to fall back to full.
11-12-2025 03:33 AM
I have the same problem but I have installed the professional development system.
Can anyone help me?
My LV Version is 21.0.1 Professional Development System
Attached is a screenshot of my Tools menu.
Thank you all
11-12-2025 04:01 AM
Compare appears only after you open a project or even a simple vi.
11-12-2025 05:07 AM
Thank you Paolo, that´s it.
