Missing software ECU simulator - Automotive diagnostic command set
Hi, i can't find software ECU simulator witch is described here http://sine.ni.com/nips/cds/view/p/lang/en/nid/203554 - "Examples for KWP2000 and UDS, including a software ECU simulator".
Can You help me find this feature of Automotive diagnostic command set ?
(5,367 Views)
nobody know ?
(5,347 Views)
By using NI Example Finder, and writing KWP2000 or UDS as a keyword you will find "Diagnostic Demo ECU", with the description: "This example simulates an ECU that implements several diagnostic protocols. If you have two CAN ports available, you can run it on one and the other DCS examples on the other so that they have a target..."
I think this is what you were looking for,
Mircea
(5,341 Views)
